Hydraulic system
In english here please
Modérateur: VINCENT
Hydraulic system
Message par moune » 26 Juil 2006, 18:38
John,
I own a Ferguson TEA20, manufactured in July of 1953 (no 337 478).
The hydraulic lifter works well and there are no power problems.
Nonetheless it is impossible to obtain a stable middle position: it is very difficult to find the proper balance and as a result the tool either moves up or down.
Is this normal? If it is not what can be done to fix the problem?
FYI: The entire hydraulic system was disassembled, cleaned and reassembled with the recommended new oil.
I look forward to receiving your answer and thank you in advance for your help.
moune
Message(s) : 4
Message par john » 31 Juil 2006, 21:51
The TE20 series and the FF30 series do not have Position Control which is what you are needing to hold the Hydraulics in a given Position. This can be fitted as an extra and then it will do what you are expecting it to do. You can find a neutral position on the Hydraulic Quadrant as it is now but it is very small. Fit an implement on the three point linkage and lift it, then move the lever slowly forward until the implement starts to drop and then move the lever slowly up the Quadrant until the implement neither lifts not lowers, first the quadrant lever marker to this point and you can return the lever to this spot each time. To make this work properly there should be very little end play in the control spring behind the seat when the implement is raised and the top link is used.
I do have drawings of a Position Control Kit you can make if you are good with your hands, if you would like it, email me direct at:- fergusontractors(at)tiscali.co.uk
when this tractor was designed it was never envisaged there would be a need for such things as it was made to replace the horse and plough, only when it was being sold in great numbers did they realise that it could be used for a lot of other things too...John
Les séries TE20 et les séries FF30 n'ont pas une commande de position est qui de ce que vous avez besoin pour tenir l'hydraulique en position donnée. Ceci peut être adapté comme frais supplémentaires et alors il fera ce que vous vous attendez à ce qu'il fasse. Vous pouvez trouver une position neutre sur le quart de cercle hydraulique pendant qu'il est maintenant mais il est très petit. Adaptez un instrument sur la tringlerie de trois points et soulevez-le, puis déplacez le levier lentement en avant jusqu'à ce que l'instrument commence à laisser tomber et relever alors le levier lentement le quart de cercle jusqu'à ce que l'instrument que ni l'un ni l'autre ascenseur pas ne s'abaisse, d'abord le marqueur de levier de quart de cercle à ce point et vous pouvez renvoyer le levier à cette tache chaque fois. Faire ce travail correctement là devrait être jeu d'extrémité très petit en ressort de commande derrière le siège quand l'instrument est augmenté et le lien supérieur est employé. J'ai des schémas d'un kit de commande de position que vous pouvez faire si vous êtes bon avec vos mains, si vous le voudriez, email je direct à : - fergusontractors(at)tiscali.co.uk quand ce tracteur lui a été conçu n'a été là jamais envisagé serait un besoin de telles choses qu'il a été faites pour remplacer le cheval et la charrue, seulement quand elle était vendue dans de grands nombres ils se rendent compte qu'elle pourrait être employée pour beaucoup d'autres choses aussi...John
john
THE Ferguson Expert ;-)
Message(s) : 120
Hydraulic System
Message par Patrick » 31 Juil 2006, 22:40
I thank you very much fou your help.
Moune (Patrick)
Patrick
