Replacing mouldboards on BBAF28
In english here please
Modérateur: VINCENT
Message par webmaster » 08 Mars 2005, 11:38
Hello John
A question from christophe
he has a BBAF28 for which mouldboards show a reference as you can see on the photo. On the basis of this reference , he wonders if it is genuine part or not ? As far as you know, is it possible today to find genuine mouldboards or if not what part could be equivalent
Thanks to ImageShack for Free Image Hosting
Message par john » 10 Mars 2005, 09:43
The answer is that it is a 12inch Semi-Digger Mouldboard and it looks to be a genuine Harry Ferguson part.
HF = Harry Ferguson,
12B is 12" and I think the B was Semi-Digger
AF = France (F) it would be E for England
Can't remember what 112 was at all, maybe it will come back to me.
To check the width of furrow, measure distance at the very top between the vertical plough beams that carry the plough bodies as it could be 12inches or maybe 14" they can do this by changing the plough shares as there are the two different types available i.e. 12inch and 14inch. There is a spacer fitted in the frame at the top where the plough beams bolt together on early ploughs if it has been converted to a 14inch model, later they had different beams for 14inch type. The mouldboard is the same for 12inch as for 14inch types. The only safe way to tell is measure between the beams at the top and then you can order the correct 12inch or 14inch share, these look the same except the "wing" (that cuts the furrow underneath) on a 14inch is longer that a 12inch. Hope you can understand all that as it is a bit complicated. As for plough parts, mouldboards etc. and shares, you can try the following:-
Roger Thulbourne Ferguson Plough Spares- parts for Ferguson and early Massey-Ferguson 793 plough's H and L Bases. Ransome Robin Parts Fergie Place, 6 Lynn Road, Southery, Nr Downham Market, Norfolk. PE38 OHU email at the FoFH Shop
Tel: 01366 377464
This came from the FoFH site:- http://www.fofh.co.uk/yellowpg.asp?c=2
and you can also try Paul at Southern Counties Tractor Spares (Carburettor kit for Christophe). If you don't have any luck with this then ask again...
Traduction (sous toutes réserves car je suis ignare en charrues... :wink: -JC)
La réponse est que c'est une lame versoir Semi-digger ( ?) 12 pouces et çà a l?air d?une véritable pièce d?origine Harry Ferguson. HF = Harry Ferguson, 12B pour 12 " et je pense que le B était pour versoir Semi-digger- AF = France (f) ce serait E pour l'Angleterre . Je n?arrive pas à me rappeler ce que veut dire 112 , mais çà me reviendra peut-être. Pour vérifier la largeur du sillon, mesurer la distance au dessus entre les faisceaux de charrue verticaux qui portent les corps de charrue car ce pourrait être une 12 pouces ou peut-être 14 ". C?est possible d?avoir l?un ou l?autre car on peut changer les lames. Il y a les deux types différents c.-à-d. 12inch et 14inch disponibles. Il y a une entretoise montée sur le dessus de la structure la où les faisceaux de charrue se boulonnent ensemble sur les anciennes charrues si elles ont été converties en modèle 14inch. Ultérieurement, elles ont eu différents faisceaux pour le type 14inch. La lame est la même pour les 12inch que pour les types 14inch. La seule manière sûre de savoir est de mesurer entre les faisceaux au dessus et alors vous pouvez commander la bonne lame 12inch ou 14inch . Elles ont la même apparence a l?exception de l? »aile » (qui coupe le sillon dessous) qui est plus longue sur un 14inch qu'un 12inch. J?espere que vous arrivez a comprendre car c?est un peu compliqué.
Quant aux pièces de charrue, aux lames etc. et aux autres pièces, vous pouvez essayer le fournisseur suivant :
- Roger Thulbourne Ferguson Plough Spares- parts for Ferguson and early Massey-Ferguson 793 plough's H and L Bases. Ransome Robin Parts Fergie Place, 6 Lynn Road, Southery, Nr Downham Market, Norfolk. PE38 OHU email at the FoFH Shop
Tel: 01366 377464
Ces adresses proviennent su site Friends of Ferguson Heritage :
et vous pouvez également contacter Paul Southern Counties Tractor Spares ) (que vous avez contacté la semaine derniere pour les pièces de carburateur de Christophe). Si tout çà ne marche pas n?hésitez pas à me recontacter
john
THE Ferguson Expert ;-)
Message(s) : 120
