power adjuster ?
In english here please
Modérateur: VINCENT
power adjuster ?
Message par webmaster » 06 Nov 2005, 11:43
Hi John
what is exactly this power adjuster for ?
jc
Message par john » 14 Nov 2005, 15:52
Hi JC, Sorry I didn't see this till today, They used this type of wheel so that you can change the wheel widths quickly, it is not as big a job as on a TE20 where you have to strip down the wheels and turn the centre dish around etc. to get the correct width. These wheels were fitted to some 35 and 135 but will fit a TE20 if necessary as they are they are the same fitting....John
john
THE Ferguson Expert ;-)
Message(s) : 120
Message par webmaster » 14 Nov 2005, 21:07
ok !
thanks John
Message par john » 18 Nov 2005, 17:27
JC. Something I didnt make clear when I wrote this. The wheels can be adjusted simply by driving the tractor forwards or backwards and it will spin the wheel centres out to the width you need.
john
Message(s) : 120
